M
Morolinith
Guest
Well my Stupid Powermaster is Going out and I want to convert to a vacuum system. I have the info from GNTTYPE.org but still have a few questions. On the 2 Papers I have from GNTTYPE.org, 1 says Vacuum Booster and the other says Vacuum Assist Canister, What exactly should I ask for at the autoparts store?
I found the Break pedal and bracket and the master cylinder is in stock at Autozone. I was planning on ordering that aluminum Vacuum block from Kirben for 34.95 to hook the vacuum line to.
Anyone have a picture of the vacuum system installed by any chance?
As you can tell I don't know much about working on cars, I just want to make sure I have everything I need so I don't have to rent a car for work.
Thank you,
M.
Thank you,
M.
