Aloha everyone!
I’m doing the vacuum brake conversion, and I can’t remove the adapter plate that converts from the 4 bolt mount on the firewall to the two bolt mounting pad. I removed the four interior bolts, and all the bolts are no longer held by anything on the inside, yet, it won’t come out.
From the engine, I pried three of the four bolts and they’re ready to come out once the fourth bolt loosens (they remove as one), but the bolt on the driver side bottom won’t budge at all. Strangely, this is the only bolt that didn’t have a nut holding it in.
Mahalo!
Mahalo!
