My air on my 86 Gn blows cold but it blows thru the defrost vents instead of the A/C vents. I took it in to have it checked out. The Vacuum canister had been removed at some point so my Mechanic replaced the Vacuum canister(ball). It still does not work. He said there was a vacuum switch inside the dash that needs to be replaced but that he couldn't find the part. He said That If I could find the part I should be able to replace it myself.
Does this sound right? I have taken the heat and A/C control out before and I don't remember any switch. If there is a switch where can I find one? Thanks, Jon
