Vacuum Hose size????????
USMC_Turbo6
Ok, I did a search an found one link, but it didn't work so I'm asking again for the help. What are the size and length of vacuum hose do we need for our cars.
I'd like to know too, I think I used to small of a T for my boost gauge off the MAP sensor and it's acting a lil odd. Comon' guys what size hoses do we need for the whole system???
Got this from somewhere and saved it.
Cruise Control Servo
Large port 9/32"
Small port 7/32"
Vacuum ball 7/32"
Washer Resevoir 8/32"
Washer Nozzles 7/32"
Charcoal Canister
To Tank 10/32"
Solenoid 8/32"
EGR to Solenoid 5/32"
Vacuum to EGR Solenoid/Check Valve for HVAC/Cruise 9/32"
Brake Booster 3/8" (9-9.5mm)
AFR 6.5/32"
Vacuum Block
3 ports 8/32"
1 port 6/32"
1 port 12/32"
PCV 12/32"
Wastegate Y-hose 8/32"
Total Lengths For Car
4mm = 122"
6mm = 147"
8mm = 46.5"
It is either:
www.gnttype.org or Vortex buicks
I believe. I have written done at home. PM me your email and I will try to find them. I don't your rubber lines anymore. I upgraded to plastic lines and pushlocks. I have enough for about two more kits...
Clint
Sent from my iPhone using Turbo Buick
Highway Stars sells the three hoses attached to the fuel pump sender.
