turbobooster
- Nov 12, 2002
Been chasing this vacuum leak for 2 weeks now and I can't find it
I hear it but can't find It, I hear it pretty clear in the area where the factory boost solenoid sensor is at it's where all the vacuum lines go to some bracket That sits on the drivers side valve cover right under the intake tube how do you guys check for vacuum leaks in that area ? All the hoses are replaced I've tried reaching there to see if I can feel it or listen to the engine sound change but no luck I can hear it though
