I've spent a good part of the day bypassing a leaking heater core. After all that, I see a vacuum line that is coming off the bottom off what I believe is the heater control valve (fairly large brass part that the shorter heater hose attaches to). That vacuum line is not attached to anything. I must have knock it loose messing with the heater hoses. Where does this line attach ?
Strange thing is the car seems to run great with good O2 numbers and no KR at 21psi boost running alky.
Thanks,
Jeff
Thanks,
Jeff
