I have some questions that I hope someone out there can answer. The vacuum line to the canister (under the air filter) is in the wrong place at the firewall (I think). I made a diagram below and it is red.
Should I remove it from the T in my diagram and re-connect it to the proper metal pipe? If so, what would then connect to the T?
The other question involves the two hard lines on the passenger side. One goes from the interior to the heater control valve which is OK but the other one comes from the passenger side fender and I don't know where it goes. Any help.
It's a terrible thing to be a noobie but I sure am learning from you guys...
