Vacuum line questions
Jon01
Just about done putting the GN back together, and I'll be damned if I can't remember which vacuum lines go where...
Does one of the hard plastic lines coming out by the a/c box go to the heater valve?
What about the boost solenoid?
A picture would be great if anyone has one. I've looked at the gnttype diagram and can't draw a conclusion from it.
Thanks for any input guys!
Jon
Yes one of the hard lines from the A/C box go's to the heater control valve. The other one go's to the check valve against the firewall between the master cylinder and coilpack. The wastgate solenoid has one vacuum line coming out of it that attaches to a "Y". The hose from the straight part of the "Y" go's to the compressor housing and the other go's to the wastegate actuator.
HTH....Bill
One of the ports is a vent, there should only be one hose going to the solenoid.
