Vacuum Question
elcaminodave
I have a 1984 T-Type and have a vacuum question. On the Vacuum Control Valve at the firewall the front outlet on the drivers side is blocked. It appears to me that a vacuum line is supposed to run from the wastegate to this outlet. Is that correct? What does it being plugged affect, if anything? Thanks.
The original waste gate actuator on the 84/85 was a two hose one. In the picture below you can see the hose that is plugged as I have a single hose one installed. The theory for the two hose was to relieve pressure while climbing hills. Not necessary which is why the 86/87 have a single hose waste gate actuator. I am going back to the double hose waste gate actuator because is sits lower and does not trach the hoodliner. Take-care- Brad
Thanks for your reply. I notice on a diagram that I am looking at that the rear outlet on the drivers side says HVAC/Cruise. Could the front outlet being plugged and not connected to the wastgate be a cause for the cruise to not work? My cruise is not working and I am trying to track down that problem. Thanks.
I am looking at the vacuum diagram and the front left nozzle is plugged. This is not your cruise problem. I would follow the HVAC/cruise line an make sure their are not leaking and are hooked up correctly. My car does not have cruise control. If this does not solve your problem I have all the Chassi and body manuels. I can look it up if you cannot find your problem. Brad
Thanks Brad. I will let you know if I need any other help. It may be a while before I try to trace the cruise problem. In all honesty it is not very high on my list right now. I just thought I may have found my problem. Thanks again.
