Vacuum ?
scrobbyd
Okay I just finished powermaster to vacuum swap on my dads GN, all is great. The only question I have is that the Brake light inside the car is staying on. Does anybody know how to make it go off without pulling the dash apart (some little trick), also what should I do with the old PM plugs?
Thanks In Advance
If your brake light is staying on you probably have air in the system which needs to be bled. Try bleeding the brakes and the light should go out! When I did the vacuum conversion I just taped up the powermaster plugs and tucked them out of the way.
