valet chip, how?
z1huggy
How can I get a stock chip for valet mode? Basically I've got a stock GN and need a chip with a, say, 3000 rpm limiter and about a 70 mph limit. At least thats what was suggested in my other post 'How to keep shop joyriders at bay' =)
I suppose my questions are: where do I get another chip so I can get it programmed? and uhhhm, whats involved in getting it done? is it expensive? :confused:
TIA
Any vendor can get you a valet chip, normally they charge the same as a performance chip.
Anyone that can burn a chip can do it really easier, set the fuel injectors to cut off at 3000 or what ever your comfortable with, Set the top speed, and I would also set the boost to say 4lb or even 0lbs.
Chuck
Originally posted by wilkinshc
Any vendor can get you a valet chip, normally they charge the same as a performance chip.[/QUOTE
True, but I do them for $15
Chuck
I can set the speed and RPM limiters, but boost cannot be controlled below 12 psi.
Please e-mail direct for info.
