Valve cover breathers??
SS/GN
I have a Kirbans style breather on the car now.Stock valve covers
http://www.kirbanperformance.com/product/242/OIL FILL TUBE, BREATHER and SILICONE SEAL KIT #1569.html
What I am looking for is a gromet so that I can use the billet base but replace the acual breather with a more stealth type unit
http://www.summitracing.com/parts/pro-141-754/overview/
Has anyone tried this.
Kevin:)
Ya I saw the bowtie:rolleyes:just looking for something black to get a stock look in case of emission police:p
Hi Kevin,
Metco have some stuff that is designed for stock valve covers that may work. You can connect this with push lock AN style 90 and use push lock hose or 5/8" heater hose into a catch can and vent if back into your MAF pipe. You will retain a closed loop system just like the factory did.
http://www.metcomotorsports.com/proddetail.asp?prod=MBR0001-10AN&cat=107
I am looking at the drivers side,to try and make it "look" like a closed cap as originalo_O .I have the passenger side all figured out;)Thanks Dave
Kevin
