valve cover question
gsbuick65
was cleaning up my covers today and noticed the p/s has a patch of jb weld in it. was on the side just below one of the bolt holes. what was this hole for?
Post a Pic. It is easy make sure the PIC file size is below 70 KB. It makes our life easier. Brad
The only holes for a Hot-Air GN valve covers is located on the driver-side for the oil filler tube/breather cap, you might have an intercooled ps valve cover that has a hole in front of it for the valve cover breather, if thats where you are describing your hole to be, if not it might have been drilled for something else and patched up later? :D just my .02 ;)
yea seen one of those, there on the front, thisis one the side just below the valve cover bolt hole, ill try and post a pic later, didnt know if the p/s cover had any way to breath or not.
