Hello, I've been trying to figure out why I'm gettin kr over 5600 rpm. Tom at Champion sent me some .060" valve shims to try to see if we can determine if it's harmonics or valve spring related. I can't get him on the phone and am trying to install them. He said to remove the steel seat and put the shim on the head and then put the spring seat back on top. However the seat won't fit over the valve guide? Also the shims do say "This side up" on them and they fit perfectly over the seat. Do you think it's ok? I also got a push rod length checker. I used a sharpie to paint the end of the valve stem, then reinstalled the push rods I have been running and adjustable roller rockers and set preload. I then spun the car over a few times. The wear pattern looks very good to me. It might not be exactly in the center on all - but very very very close. Close enough it was hard to identify. So basically I didn't even use the push rod checker. Am I missing something?
Darren
Darren
