valve tips
Bobs rare 6
I just got my iron heads back from the machine shop. Had them vacum checked and inspected. A couple of intake valves were leaking so they did a valve job. They also grond the tops of the valves. They said they are wearing uneven. You can still see some side wear on the valves. Am using stock rockers on H.D. shafts. Is that typical wear or should I look into different rocker ass. Thanks, Bob.
Nothing to worry about. It is a metal to metal wear surface. Normal for a wear pattern to exist.
