7
78TurboBuick
Guest
As you can see by my name I have a 78 Turbo Buick. Im having problems with some vacuume leakage. I have one part in particular that is at fault. It is called a turbo vaccume bleed which screws into the intake manifold. It has 3 vacuume lines that come out of it. One of which goes into the back of the wastgate acctuator, one which goes into the back of the carborator, and the last one connects with the whole system of vacuume lines in the front of the engine. I need to know what the valve does if anything and also if i could find one around anywhere. If you can help me please gimme a thread back.
Thanx alot
The part is the Power Enrichment Control Valve....GM part#1260447
Thanx alot
