VDO sender part nbr
IowaGN
I need the correct VDo part number for my 80 psi oil gauge. I know there are two ways to look it up. On the sender itself there is a number, and the 6 digit VDO part number. Either one would help.
Thanks!
Travis
360-005 VDO pressure sender, 10-180 ohm, 0-80 psi (single output)
360-019 VDO pressure sender, 10-180 ohm, 0-80 psi, 8 psi warning contact (dual output)
got mine here: http://www.egauges.com/
David
Not sure if it would. I used some fittings to make it stand straight up near the original's location. I'd have to look at it tomorrow. Could possibly get a pic for you. Maybe someone else will comment here.
David
Correct part numbers
Travis,
The correct part number you want is 360-005. This is the single terminal sender with 1/4"npt thread that will screw directly into the block. Part #360-003 is 1/8"npt and can be used if you are using a 1/4" bushing or a "t" block.
I have both in stock.
Tom Houser
Performance Instruments
www.gnxdash.com
