I found the problem with my a/c -heater vents just blowing air from the floor. It turns out that the problem is the foam rubber seal around the vent control door detoriated. This lets the air escape mostly from the floor, a little bit from the top vents,some from the defroster, and none from the side vents. I had to take the whole dash out to pinpoint the problem. I hope this helps some of you guys with the same problem I seen recently. Now my ? is Where do I find this rubber foam seal or a replacement door with the rubber seal all ready on it.
Nick
Nick
