captndave737
- Feb 14, 2006
I suddenly developed a massive oil leak, like a quart every 150 miles. I'm glad this happened after the 2500 mile trip I just took.
I checked the usual suspects; valve covers, oil pan, front seal etc. all were dry but the leak was coming from the front. I traced it to the bolt that goes through the upper hole in the crank sensor through the front cover. I figured the bolt wasn't sealed well since I just put on a new TA Performance front cover 2 months ago. I resealed the bolt and still had the leak!
I removed the Crank balancer and sensor and saw the cover was cracked around the bolt! When I removed the cover I placed it on a flat surface and it was almost 1/8" from being true.
I checked my old Chinese cheapo that I replaced and it was nice and flat. I guess I should have checked the TA cover before I put it on but everything else was machined so well I didn't even think to do it. It's unfortunate that every part you get for these cars has to be checked and double checked no matter who the vendor.
