xspetsnazx
- Apr 15, 2010
Finally made it to the track to see what my TTA runs. I had stock worn tires and no work to the suspension. I wasn't too happy with the results. First run was horrible 9.203 @81.2 MPH with 2.214 60 foot time. Tires spun whole way though the 1/8 didn't grip at all and I didn't even spool it, just floored the gas pedal on green. Second run was a little better on the 1/8th 8.722 @85.0MPH but worse on 60FT 2.325 still spun half way down the track. On third time I released some tire pressure ( by counting to 20 on each side, rear) and had a little better burn out, still by just flooring it, time improved a little more 8.593 @85.7MPH & 2.306 for the 60FT. I just wanted to see where I'm at so far since I've never been to the track before. Car is out of tune and I know I need better tires so they can stick because it had no traction, the water from water box didn't help neither. I don't know why the 60FT was so bad tho.
