Originally posted by TT/A1233
Be wary of moderately/highly modded Turbo Regals. They need to be modded with the proper combination of parts in order for it to perform well and not take longivity from the engine. Detonation/knock is KILLER to these engines and if mods aren't done properly engine life may suffer. The LC2 powerplant is extremely tough contrary to the stories that turbocharged engines die quickly.
Standard doctrine is that 1986-87 intercooled versions are most desired for performance purposes. For rarity, the 1984 GN, 86-87 Turbo Regal Limiteds are up there next to the 1982 GN.
Some of these have already been mentioned but I'll hit'em here:
- Sensors may be bad. My 1st GN had one under the hood that rusted out causing the electric fan to stay on. Buick didn't make it waterproof - it's a common problem.
- Doors can rust out if they're from northern states and winter driven (road salt).
- Original paint was horrible.
- Power antenna may freeze.
- Original parts are getting hard if not impossible to find.
- Transmission TCC solenoid usually goes out quickly. This causes very premature torque converter lockup. Inexpensive, but messy fix.
- Powermaster break system (not sure why Buick tried to re-invent the wheel). Buick has an electric motor to create vacuum instead of it being drawn naturally from the engine. Pontiac chose to draw off the engine instead in the TTA, a no brainer.
I've owned 2 GNs and one 1989 20th Anniversary Turbo T/A and have had virtually NO mechanical problems to report, though most of my LC2 cars have been low mile cars. I had my 1st GN from 17,000 mi - 78,000 and had the TCC problem, sensor problem, powermaster break issues and due to my neglence blew a head gasket....that was it.
I haven't had the money pit problems some report. I suspect those cars have been run hard and/or been high mile daily drivers including possible hard winters. Aside from some of these problems outlined here I'd recommend a Turbo Regal to anyone looking for a ride offering comfort, good fuel economy, creature comforts, trunk space, a bit of rarity/legend and the possiblilty of [cheap] KILLER performance if one chooses. I've been in some pretty tough performance cars and what the TR offers makes them pale in comparison. I'll have one forever.
