Vibration in neutral
gotsmoke?
Just picked up my first TTA. I have a couple older TA but finally got a TTA. It has 50lb inj, TT chip, hot wire pump, and a aftermarket reg. I knew when I bought it that something was a little funny. The trans has a vibration in park or going down the road. It changes with engine speed not wheel speed. I have clocked the covert to all three positions. It will not lock up going down the road. The car has 47K and the trans was re-built about 1500 miles ago. I don't know the builder. The flexplate is fine and the vibration is not there when then engine runs disconnected from the trans. The scanmaster shows all good. I have check the plugs and wires and have no vaccum leaks. I am starting to look for a new convert. Is there something else that might be missing? Thanks
So if you rev the engine in park the vibraion is there?Did you check engine and trans mounts?Exhaust hangers?Does it go away at certain rpm ,or road speed?
Vibration is there at all engine speeds, just varies in pitch. Exhaust looks fine but have not checked motor mounts. It never really goes away, just better/worse.
