Viking Coil Overs, Accufab Throttle Body+Plenum and Misc.
JEvans22
Viking double adjustable 2-3 in lowering coil overs with relocation brackets and shock mount reinforcements. Rolling thrust bearings and spanner wrenches also included. I’ll make sure to provide all hardware needed to install.
700 shipped
Accufab throttle body, gn1 plenum. Throttle bracket and iac housing included.
420 shipped
Gn1 billet throttle body vacuum block with brass barbs included.
90 shipped
Bronze powder coated matching set of valve covers, accessory bracket and cold air pipe. In very nice shape.
250 shipped
Shifter plastic slide.
30 shipped
Steering column plastic guard.
30 shipped
PP preferred
Thanks a bunch
I do not want to touch the front end as it has been rebuilt and all adjusted. My concern is they will at least set the rear end as high as it sets now.
What spring rate are the springs ?
What makes them 2-3 lower ?
150lb spring rate for street and handling. The coils ride on washers which can be turned for the height to be set. With the spanner wrench you can turn the thrust washers to either put more pressure on the spring which will raise the car or vice versa to lower the car. I almost had the coil overs adjusted to the highest point and they are just about the factory ride height. Once they are in that’s it. No more having to swap springs to adjust height. With a turn of the spanner wrench you can adjust the height accordingly.
I do need the TB but already have a plenum....any chance of splitting them up? Thanks!
