I cant find the problem with this car , it will run and drive with the batt voltage about 12-13 volts. But if i start to rev it high 3500-4000 and build boost the voltage on the turbo link says it drops any where from 6.0 to 0.3 volts. Then the car fells like the valve are floating and wont really rev and the knock gauge go's crazy, scan tool said at times 30* ret i hope that is wrong.
I had the alt tested and it put out 15 volts, the batt is new , coil is good and i try others and the same thing. I even put 110cam2 in it to day and the same thing . I dont no where to look now. How does it stay running at 0.3 volts and 30*knock ret.
help
help
