VSS Question
N2BUICK
TurboBuick.Com Supporter!
Does anyone know the difference in a VSS that uses 4 wires as opposed to 3 wire set up?
The 4 wire set up uses 3 wires into one female terminal. The 4th wire is a single red to a one wire female terminal.
This is on a wiring harness that I think came out of a 1987 digital dash car?
I have another harness that has only the 3 wire connector. Is this standard on a standard Regal?
Just trying to help another guy find some parts. I should find my wiring diagrams, that would help
the single black connector red wire (4th wire) goes to the cruise harness to the supply VSS for the cruise brain box, if you dont have cruise you dont need that connector
