You should try cranking fuel vs coolant temp first. Long crank times are usually caused by too low a PW. (Takes a couple squirts to puddle enough fuel to fire) What I did (right or wrong) is bump it up till starting the car resulted in it having to clear out, then backed off a little till it started clean. Same with afterstart vs coolant temp (Cause of the start/stall syndrome). I richened it till it needed to be cleared out, then backed off a few notches. You no you backed off too much if the car needs to be goosed to stay running. Just add like 1 or 2 more notches (pretty scientific huh?) and it should be perfect.
