Jan 14, 2004 #1 Y y-hate Gone In Sixty Joined May 30, 2001 Messages 464 I want to move my spray nozzle closer to the TB, what do i use to plug up the old hole in my up pipe....
Jan 14, 2004 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,002 Leave it in there with the NPT elbow on it and put a cap on the NPT other end. Or solder over the hole in it and leave the nozzle. Or use a nut and bolt with a sealing washer on each side. Or duct tape or jb weld.
Jan 14, 2004 #3 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 Leave the nozzle alone.. Moving the nozzle a couple inches makes no changes. If there is an issue, its usually not the nozzle. Hope this saves you the trouble. Duct tape is way over rated
Jan 14, 2004 #4 Y y-hate Gone In Sixty Joined May 30, 2001 Messages 464 Gotcha, but it is right at the bend of the up pipe............ is that ok..plus i`m installing a ATR BOV don`t want alky to mess it up will i be safe from alky
Jan 14, 2004 #5 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 BOV See ya didnt mention this. I would install nozzle after BOV. You have a front mount on the car yet, if so..typically mount the BOV on the bottom under the radiator area. I would be safe to assume its best to keep alky away from your BOV. Cheers.. Julio Keep those white tip things away as well
