Wanted: BRF transmission
Cale22
Doh!
Anyone have one for sale? My trans is shot, I need a good working BRF trans, thanks.
Still trying to fix that trans, huh? Same here.:rolleyes: What are you going to do with your old BRF valve body? Ever think of just rebuilding that one? I have 5 here with only one working correctly, and that's the stock one that came in my white one. I decided to try and do the task myself:eek: taking it apart was no big deal, it's the putting back together and WORKING RIGHT is the scary part !!! Waiting for parts from Bruce. Good luck with yours!!!:)
Hey Paul-
I 'thought' about rebuilding it, but here's the thing. It turned out to be a Monte Carlo transmission (non HO) which Jack Cotton said can actually cause problems even with the BRF valve body and governor. The BRF transmission I bought, turned out to be a BQ valve body (and the 1-2 shift valve is no good) we tried taking it apart and sanding it down, but after running that VB in the trans, it killed the clutches, yikes. I know what you mean about assembling the valve body, when I took it apart, I was like WTH ARE ALL THESE LITTLE PIECES! haha. Good luck to you Paul!
