Wanted to share fuel line info with the group
anthony605
Hi guys!! I wanted to share some info with ya....A while back I made a post on the group asking how to plumb 6AN steel braided line for fuel return. The problem was there was no adapters made that would clear from the bottom of the regulator to the top of the intake manifold. A normal 90 degree fitting would not clear. The ony suggestion was to weld a 90 degree fitting to the bottom of the regulator. Here is how i got around it. I bought an accel TPI kit (accell #74730). This kit includes a straight saginaw to 6AN fitting. It has another fitting that you dont use....sell it on ebay. Then i got a funky shorty 90 degree 6AN fitting (Earls #921106). It actually clears the intake by a very very small amount!! I mean its no small the hose fittings flat end has to be parallel to the intake! It works and im happy! My car is a conversion and i had to use steel braid....i wasnt going to bend steel line.....I hope i helped somebody else!
The Accel kit is $30 and the Earls fitting is $13. I am going to sell the other fitting that came in the Accell kit on Ebay. Hopefully i will get $10 for it. As far as the supply line, I had that done with 8AN. I had some adapters that i got from Eastern Performance from a few years ago. .....
