quickstrike
- Jun 4, 2002
I searched alot of the old threads first, but cant find the answer there.
Eng is a 331ci, with 83lb inj. At initial startup with cold CTS reading, all is ok. After eng reaches 180 or so, car does not want to restart without alout of pedal pushing. I have read through the manual,(excellent help manual by the way,answered damn near every question so far) and understand that I can adjust both the Starting IAC position and the Cranking fuel pulse width. I have tried various things to an extreme without much success. I understand that by looking at the BPW at a warmed up idle and then add 50% more inj puls width to that and ramping it down from there should work. Does this mean if my BPW is 2.5 at idle, that I need to set the Cranking fuel to around 3.75 and ramp it down to a warmed engine from there? Beacuse the only way the car wants to start is around 25 ms of PW and ramping it down from that point. Although the car still doesnt want to start when warm even with that. I have tried opening up the IAC at startup to 255(max) and still I have to pedal it to start it.
By the way setup paramaters have my inj delay at 1.0ms. car runs and idles pretty good except for this problem. I am new and learning quickly though. My 2 best sources of info are this site which is great, obviously some very intelligent tuners here, and also the FAST manual which was certainly careful written to answer most of the basic questions to get you up and running.
Please help a FORD man out, I promise I wont tell a sole! Thanks in advance for any help you may offer.
P.S. base timing is 10 deg(checked with light).
Randy
Randy
