meanchicken
gallo vicioso
- Oct 6, 2007
See if this makes sense.
Can a smaller inner diameter vacuum line running from the turbo inlet to the actuator actually impact how soon the actuator opens? can a smaller diameter line cause the actuator to open sooner (i.e. at 11 lbs vs 14 lbs)?
Or could a longer than normal, smaller diameter line do this?
The reason I'm asking is because...
In my quest to eliminate KR until my Alky kit arrives and is installed, I have removed my RJC boost controller and adjustable WG actuator and reinsatalled my factory vacuum line arrangement (sort of) and WG actuator. I did things one step at a time. I was having that boost spike and creep issue described in my seperate post and have not opened up the puck hole yet cuz I know and accept that making my car higher boost capable before I add alky is a recipe for BOOM on 91 octane.
I couldn't get less than 16 lb of boost (with a spike to 18 at WOT) with the RJC controller and adj actuator
So first I pulled off the adj actuator.
Still couldn't get lower than 16lbs so I pulled off the RJC and installed the hoses per the factory arrangement, but I used longer and smaller diameter (what I had readily available) vacuum hoses and routed over the top of the turbo so that I didn't have to turn the fitting on my inlet bell back around.
The result is that I max out at 11 lbs of boost and wouldn't you know it....0 KR no matter how hard I try.
Should be able to hit 14...right? That's where I was before I added the RJC and adj actuator.
...now the car can barely get out of the way of a peppy soccer moms SUV...
So just for fun, I'll be trying some larger diameter hoses to see if I can "hose tune" the car for a couple more lbs without returning to KR issues.
...but does this make sense???
