Just want to make sure this is correct.... Installing a GT3255 and the new wastegate actuator ( the one with the bracket welded on to it) Do I need to remove one of the housing bolts and leave it off to install the actuator ? The bracket on the actuator has a hole that mounts in the front, then skips over the next hole and has another hole to mount in the rear. If you dont remove that bolt in the middle it wont sit flush against the housing. Is it okay to leave one bolt out ?
