Does a higher value for wastegate duty cycle percent cause the wastegate to open the puck further or close it more for higher boost?
There are 2 tables, one vs. RPM the other vs. TPS. In the TPS table, I have all 99.6%.
Reason I ask, is I see values of 0% at 1600 and 2000 rpms which I would think you would want the puck closed as much as possible for better spooling at low rpms. Then at higher rpms I see values like 99%, maybe because the higher rpms would generate a lot more boost if the puck was not fully open????
I always figured before that higher values meant more boost but after noticing the 0 values, maybe not.
