Wastegate flange assembly
ttypewhite
This wastegate flange assembly fits a stock style 3 bolt turbo housing. This came with my 5" downpipe which I had modified to work with a 4 bolt turbo housing. For those of you who like to fabricate your own stuff. This is great for somebody looking to make their own downpipe. asking $100
Can this be used with a ATR style 3 in dp...I have one that is setup for an external gate..would like to use a standard w/g assembly...
Let me know thanks
Steve Chambers
This wastegate flange was intended for a 4" to 5" downpipe. I used had the V- band flange neatly cut off the wastegate assembly so I could weld it to my 4 bolt turbo so i don't have to cut my new downpipe. This wastegate assembly would require a new flange to be welded to it and matched up to what ever downpipe your trying to build. If your trying to use this on a 3" downpipe your gonna have to be creative because the overall size of the wastegate assembly is bigger then 3".
