Wastegate movement
D's GN
Hey guys, this is sort of an odd question but does anyone know how far a HD wastegate will push the puck open at full extenstion? Pulling a shortened wastegate arm 1/4" to the puck takes a bit of strength so I don't see it actually using up the full travel of the arm when controlling even at higher boost level.
I use a Q-boost controller which works perfectly on my car, it is advertised to stay mostly shut until a preset boost level depending on the set screw, just curious if the action of the wastegate is instantaneous causing the puck to fully open or partially?
