Wastegate "Y" restrictor orifice...
S10xGN
RETIRED!
When I redid my wastegate hose, I found an orifice installed in my (previously) handmade "Y" connector. Could not find a reason for this, but then again, it's been over 8 years since building this thing...
What's it for, what size should it be, and should I replace it?
Old trick I was taught long ago is to place a small restrictor in the line that leads to the wastegate, causes it to open later, hence more boost.
Was this a stock, factory item or a performance mod? Debating on whether or not to reuse it...
Every GN I've ever seen, my two included, came with gray "Y's" from the factory.
The wastegate hose on most owners cars has probably been replaced a few times over the years. The replacement part was gray and as I recall, those were identical to the TTA spec with the smaller hole in the orifice. I think they were the only ones available from GM for the last several years and, typical GM, crossed the parts over to the available ones.
That's where the confusion set in. To get the proper boost control, the restrictor needs to be 0.050".
Going from memory here....
Good memory, John. in addition, several years ago there were a few factory wastegate hose asseblies floating around with restrictor orfices that were drilled too small causing over-boost conditions on some cars. Here's the contents of a letter we wrote to GM at the time explaining the problem. So, if you have a factory assembly, it's worth checking to make sure the restrictor hole is .050 as John as said.
Holler Oldsmobile
1970 N. Semoran Blvd.
Winter Park, Florida 32792
Attention: Tom Moon, Parts Manager
Subject: Part Discrepancy, P/N 25525576
Dear Tom,
This letter describes a problem that has occurred with a number of new Wastegate Hose Assemblies, P/N 25525576. This part is installed on 1986/87 Buick Regals with the LC1 Turbocharged 3.8 Liter V6 engine. (VIN code 7). This problem has been reported to us from other areas of the country as well as here in Orlando.
The following is a description of the function of the part, the problem it causes, and the apparent reason for the problem:
The Wastegate hose assembly consists of three vacuum hoses connected by a “T” fitting. It connects the turbocharger compressor housing with both the Wastegate actuator and the Wastegate solenoid. Its function is to route boost to the Wastegate actuator in order to overcome the actuator spring, allowing the wastegate to open, bypassing exhaust gasses around the turbine wheel. This process limits the amount of boost in the intake system to a specified level.
Several individuals have reported that when installing a brand new hose assembly the engine began to experience an over boost condition, resulting in severe spark knock. Upon examining the ECM data it was found that ignition timing was being retarded as a result of the severe knock. The problem could be cured by installing another “known good” Wastegate hose assembly.
Upon close examination of the suspect hose assembly the reason for the over boost problem was found to be in the “T” fitting. The fitting contains an orifice in that portion of the fitting, which goes to the turbocharger compressor housing. The diameter of the orifice in a properly operating assembly is about .050 inch. The orifice in the defective hose measured less than .035 inch. When the .035 hole was drilled out to .050 and the assembly reinstalled, the problem was cured. The smaller diameter orifice was not allowing sufficient boost signal to overcome the spring pressure of the Wastegate actuator, causing the over boost condition.
We have talked with a number of individuals on several Buick bulletin boards on the Internet who have experienced similar problems and feel that it may have contributed to an occasional blown head gasket. We have asked that anyone having a “suspect” hose assembly measure the orifice or send the hose to us to measure. We ask that GM take a look at samples of your inventory nationwide to see if there are any of these bad hose assemblies still in the system. Please keep us informed of your progress.
Respectfully,
Ray F. Kammer
Chuck McClellan
Central Florida GN/TType Club
Well, I don't know. I do know that I still have the originals off both my GN's and they are gray. I'm the original owner of the 86 BTW, so.....
And I got the 87 VERY soon after the original owner decided to sell. They both came gray from the factory.
Original on my 86 was Gray
is there a replacement part for this or an alternative option i just cracked mine last night
The air pressure in the hose that runs between the solenoid and the actuator is what opens the wastegate and keeps boost in control. It's a balancing act - the branch of the Y with the orifice in it lets air into that hose, and the solenoid lets air out.
If the orifice is too big, or is missing, then too much air gets into that hose, the pressure goes up because the solenoid can't let enough out, and the wastegate opens prematurely resulting in low boost.
If the orifice is too small or gets plugged up, then not enough air gets into that hose, the solenoid lets too much air out, the pressure in the hose drops and the wastegate doesn't open. Result is high boost.
If you can't get a replacement Y with the proper orifice size, you can use a regular tee with a little valve placed between the tee and the turbo. It will act as a variable orifice. Something like a needle valve with a fine adjustment would be best. I would first blow through the old Y and get a feel for how much resistance it has, and then blow through the valve and set the valve opening at about the same resistance, or to be safe a little less. Or you can just start with it wide open (i.e. "big orifice"). Run the car, see where the boost is. It should be low if you were conservative on the valve position. Pinch the valve closed a little bit at a time (making your "orifice" smaller), checking to see where the boost is at, and pretty soon you'll get it right back where you want it.
This would also be another way of setting your boost, an alternative to adjusting the wastegate rod length or modifying the wastegate solenoid settings in the chip.
First, get a set of small drill bits and use them to measure your orifice size so you know for sure what you need for your current wastegate setting. Then carefully cut the broken tee open and extract the orifice, it is a little cup about 1/8" long with the hole in one end. Measure before extraction just in case you have an accident :-). If you find a real GM one, double check the new orifice size before you install it so you don't have a boost surprise. If you can't find one, go buy some plain tees and find one the right size to press your old orifice into, and presto, new restrictor tee. You may need to slightly ream the inside of a tee to get the orifice to fit, that's actually good, just stop drilling before the branch to leave a step to keep the orifice from being able to blow all the way through. Make sure the orifice is facing the same way as before when you press it in, and install the tee with the orifice connected to the turbo compressor outlet hose.
