I was making my first pass down the track and half way the engine lost all power, did not die though. Now at an idle it is just dumping a lot of fuel puffing some black smoke. You can give it some gas and it clears up but just for a little bit as soon as it starts to build boost it just kills over and tries to die.
I have a FAST computer. With the car running it is about 10 on the a/f ratio, and my O2 correction % just shows 0.0 all the time. Is there any way to test and see if my O2 is bad? Or could it be my 3 bar map? The stupid O2 sensor is $500.00 bucks!! Alot just to be guessing. Thanks in advance. Please help.
