ablackFormula
- Mar 16, 2004
I didn't get any replies to my last post about hooking up the FAST and the car not running, and I got past that problem (ended up being screwy IAC values.) My WBO2 sensor keeps reading 15.9 as the actual ratio and the number does not change... how long does it take for the O2 sensor to heat up and start changing values, or am I likely to have already melted a wire to it? Also, how do you know when the system is in closed loop?
TIA,
Rob
TIA,
Rob
