WB vs NB track benefits
Swede2
I dont know anything!
Hello!
I am looking into getting a PLX WB device. What I wonder is how big difference it was from the time you went with the narrowband tuning to the time you went to the track for the first time with WB tuning.
And is it hard to tune with WB, how much time does it take aprox,
So your best time from the time running NB against the first time running WB would be nice to know. :D Sorry, my keyboard is a mess, cant write any questionmarks... Right now I have a hard time tune my car, the KR on Scanmaster is not that high but its comming rather often, but mostly on shifts. Its hard for me to tell if its real or false knock:frown: Altought going on a low boost around 17/18 psi.
Greetings Daniel
wb02 + powerlogger + tt chip (6.0 or SD)= closed loop operation with air/fuel target setting at wide open throttle (will add fuel if running lean, and pull fuel if running rich to keep your preset target air/fuel ratio).
this is the setup I am going to now with 60# injectors and alky.
check out the turbotweak.com website.
