weber 212-206
william B.
need the specs for a weber billet 212/206 roller cam so that i can degree it in. thanks . will be installing it in a stock piston short block with a rjc girdle,also has ported champion irons and a 62/62 turbo. timing set has 4 degrees advanced and 4 degrees retard options. with the low comp should i mess with the cam timing ?
Contact Weber for cam card specs that will tell you how much advance (if any) is built into the cam. You'll need to set you timing set up to reflect this. Suggest you degree cam to verify all is within spec
