- Oct 6, 2003
Hi, I have a rebuilt trans with pat's 3000 lockup. (The trans was rebuilt 11 yrs. ago but sat on shelf) I asked the builder if he recomended a tear down he said no just go ahead and run it. Well it worked great for a couple of weeks, Then it started to act funny. When it is cold it shifts great. then when the car warms up (Engine above 170 Tranny?) the car never gets above 180. It will start to hold 2nd till above (30mph 2400rpm) The car sometimes bangs back and forth from gear to gear. this is with very light throttle, If you lay into it a little it will shift hard at about 3000rpm. If the car cools down about 160 165 It will start shifting OK again. It is only noticable when you are cruising really slow like when you are trying to maintain 30-35mph. Does this sound like internal problems or valve body?
Thanks, Mike
Thanks, Mike
