Weird Problem
Ram Air TTA
Yesterday I started my car it ran fine, I ran upstairs for about three minutes
when I came down the car had stalled. I started it back up and it had a real rough idle and my check engine light was blinking( not like when you reading the codes, but more like turning a light switch off and on fast) I tried to rev it a little and it seemed to clear up. I put it in drive and it seemed to stablize. Drove the car and all seemed fine until I turned back into my drive way and it stalled again with check engine light now on. When I read the codes it gave me a code 42 and a code 43. I went ahead a did a visual check and everything looked good and tight. I cleared the codes and restarted the engine, I let it idle for about five minutes and then shut it off, when I restarted it was rough again and the blinking check engine light was back,and now it is giving me just a code 42. I have narrowed the problem down to ECM,IGNITION MODULE,ESC MODULE. Any other thoughts or ideas??? :confused: :confused:
Clean and reset the chip, see if it comes back. Check for moisture in the kickpanel area.
sounds like the car doesn't want to be sitting in the driveway. Have you been neglecting your GN's desire to be spanked at least once a week???
