weird scanmaster problem
need boost
got boost? you should!
Staff member
Finally got my t-type up and running again from the motor build but I can't tell what is going on so I have to get this fixed! When you turn the car on the scanmaster will display 2.0 then go to flat bars like usual. When you crank the car it will show the O2 changing up and down like it should BUT when you hit the button to go to the other readings it will just flash one dot real fast in the middle till you turn loose of the button then it will show the O2 again. Will not scroll to the other stuff any ideas please!!!!! Daniel Ray
You're pushing the wrong button. That's the button to display saved data (only displays saved data when you've been WOT for 3 seconds or more).
Duhhhhhhhhh
Good grief duhhhhhhhhhhh man I have NOT been getting enough sleep lately and its been way to long since I got to drive it!!! Almost 9 months , I can't believe I did that lol. Thanks Dave from the ignorant no sleep man Daniel Ray :D
