Weldon pumps.
Cheeseburger
Fuel pressure bleeds off immediatly after i prime motor, i guess they have no built in check valve whatsoever, correct?
Thanks.
weldon pump
2025a pump #10 an line, never used a check valve and i dont need one, worked for 9 years, no trouble good luck oc, :)
I hear you, i like to run a check valve because it allows you to see if you have an inj leaking down and it allows faster starts.
I used to have an SX check valve, but that's gone and it looks like the Earls is the same.
2 2035s? How much horsepower do you plan to make?
I believe 1 is good for 1500Hp or so.
Mike, what is your line size? I have a -10 check valve that I have never used, maybe you could have it if it'll work. Shipping to canada sucks though... :eek: :D
Sure that would be great,(using -10) how would you like to go about it?
You can email me direct at prov62003@yahoo.com
I have a few ''tricks'' to get things shipped without being robbed at the border. ;)
Talk to you soon!
Thank you,
Mike.
turbodave231 said:
Two 2035's?? Why? You will need a high flow regulator and a huge return line.
Lol, i was just having some fun. :D
I have one 2015, man this fuel system really ate up the cash! :o
I did a single 2025.
I know what you mean about the cash. When you start adding up receipts..............no wait , you don't want to ever do that!
It seems like everything costs twice what you originally thought.
DR
