wet plug...leaking inj.?
87NAT
In Between GN's
I bought my 87 gn with only 48k but it was stored for 6 years and only started maybe once or twice a year. i have 009's and one spark plug is always wet when i pull it. My fuel pressure also does not stay constant after i shut the motor off, it bleeds down quickly. my question is: Is the inj. leaking like i suspect? If so should I change all of them since they sat for so long? Also, is my performance suffering right now from it or am i just leaking gas and fouling a plug out? any help would be appreciated.
That's what it sounds like is happening. If you want to go through the trouble to find out if that is what's happening, put the suspected leaking one in a different cyl. If you have plans to go with bigger injectors, change them out. It could be a broken o-ring. It could just be a piece of dirt that's got it stuck open. Same thing happened to me when I put 009's in and it cleared up after a few weeks. I guess it dislodged itself.
It certainly is not helping anything...
