wet sand paper
mybuick
intercooled engines rule!
is there any 1,000 grit paper that is sticky for sanding blocks and where can i get it, eastwood dont have it. or if there is a glue that will let me put on the paper and take it off to put another piece on, that would work to.
Check harbor freight, Their tool are not the greatest but they might have what you are looking for. They have it for DA, not that i would recommend using a DA , depends on the size of your sanding block. Justin
