whare do i put the IAC
Oops yep your write the mat sensor so it doesn’t matter where I put it could I just hang it someplace or does it have to be with the air flow.
It wont give your computer an accurate reading unless its in the MAF pipe. MAT= manifold air temperature sensor.
Mine is in the plenum. That way you can measure the temp. of the air coming into the engine.
