Per Thrasher website, if you get TPS to 4.0 then you are good, for PE mode. This is 80% of 5.0. See #6 in this link. http://www.thrashercharged.com/chips_htm/cal_hints.shtm#5
SignUp Now!Thank you Earl. Hoses replaced. Boost not going over 15 psi. At WOT. zero knock. 690 on O2.touch the three rubber hoses connecting the turbo to the wastegate. If your fingers turn black, replace them with new hoses.
If they don't turn black, replace them anyway.
Finally put some miles on the car this evening. Notice the shift getting funny, especially from first to second. Kinda a slipping. Reset the tv cable per vortex buicks. Back to nice firm shift.Larrym right on the money. Working on vacuum leaks as far as hoses and connections, but can't get my BL off of 150 at idle. Noticed a cracked check valve from the vacuum block before it tees to the egr and points sorta uknown at this time. I'm gonna order a block off plate for the egr and try to remove as much un needed vacuum hose as possible.Other than the simple connections, what needs to stay?Pop like the tranny TV cable ratcheting probably why the WOT TPS reading was off.
