What chip is this?
Caleb W.
What chip is this. I'm 99.99% sure it's a Turbo Tweak. And how old is it. Should I replace with the newer 5.7 TT?
It allows the low gear timing to come in quicker. All you have to do is move the low gear timing from 128 to 129. A full explanation is on Erics site.
Would there be a benefit for me to switch to a 5.7 Street chip or keep this current one. I read on Eric's site that his Alcohol chip is for straight methanol injection. I run a mix and plan to forever. I'm not sure of this 5.6 specs for an alcohol chip. Yeah it says timing and boost preferences but I'm not sure if it's right for my setup
If you run alky...then stay with the Erics alky chip. As I stated above, his 5.7 alky version incorporates 'aggressive mode'. The quicker you can get the low gear timing all in...the quicker you can come off the line.
