Ok..so I took the GN out for a test spin this morning. This was the first time I have driven the car since the rear the rear u-joint let go back in September.
She doesn't want to shift now. It runs all the way up to high 4000's and if
I let off the gas a bit she will slide into 2nd. Never got out of 2nd gear
but I didn't have a lot of test road. Not anxious to get too far from home.
I have an Art Carr shift kit that used to firmly bang between gears.....that
is not the case now it seems.
I checked fluid level and trans cable and reset it per the usual method.
Still no crisp shifts and almost no shifts at all :-(
Soooo..........what do you think is up with the trans? I assume it was not
amused by the sudden loss of resistance at that high speed in 4th gear.
Is it time for a rebuild? I don't think I have line pressure any more :-(
Thanks,
Bill
Thanks,
Bill
